ST7 bubblesort
baggio10
Posted on November 24, 2003 at 08:11
ST7 bubblesort
baggio10
Posted on May 17, 2011 at 10:16
I'm at the beginning with st7 programmation and i'm looking for a program that implemented the bubblesort algorithm.
Thank you that help me
alain239955
Here is the C-code
void swapElements(int a[], int maxPos, int last);
void bubbleSortPhase(int a[], int last)
// Precondition: a is an array indexed from a[0] to a[last]
// Move the largest element between a[0] and a[last] into a[last],
// by swapping out of order pairs
int pos;
for (pos = 0; pos < last - 1; pos++)
if (a[pos] > a[pos+1]) {
swapElements(a, pos, pos+1);
// Postconditions: a[0] ... a[last] contain the same elements,
// possibly reordered; a[last] >= a[0] ... a[last-1]
void bubbleSort(int a[], int n)
// Precondition: a is an array indexed from a[0] to a[n-1]
int i;
for (i = n - 1; i > 0; i--)
bubbleSortPhase(a, i);
// Postcondition: a is sorted
Reference:
www.amberman.org/evolve/Transparencies/ch5.ppt
Good luck
