2024-09-10 2:38 AM
There is confusion about resistor values on input voltage divider.
According to datasheet voltage on MPP pin should be lower than 2.1 V (Vuvp - 0.1V)
In application note AN4397 you used UVP set by resistors R4, R5, R6?
Which value should be used?
