SPV1050 LDOs connected to store or to battery?
soren
Posted on March 06, 2016 at 10:45
(Text was missing in my 1st post. Did not work from mobile?)
Hi - does someone know whether the two LDOs on the SPV1050 will supply power even when the charging circuitry is disconnected from the battery (!BATT_CONN is high)?
My application should get LDO power all the time, but it only receives IN_LV recharge voltage some of the time. Is that supported?
Kind regards -
#spv1050
0 REPLIES 0
