Power supply no output
Akinfo
 Anyone can tell me this component  name  
4 REPLIES 4
Guru
Possibly a fuse, inductor, or capacitor.
There is neither a fuse nor an inductor.Maybe it is the capacitor. But it is not known what type of capitor it is. So that we can place orders in the market
Peter BENSCH
Well, the only thing left for you to do is to contact the manufacturer of the board so that he can tell you the type and parameters of this component. If they don't reply or reply in the negative, they probably won't want you to rebuild their board.
Good luck!
/Peter
It has C6 right next to it. Certainly points in that direction.
We have even less information than you. None of us can tell you what that is specifically based on a picture, certainly not at the level you want--a part number that you can order.
It should be straightforward to desolder it and take measurements with a multimeter to gain a better understanding.
