please reply my question regarding L9396 and WSS PWM Data
jwprk123
Hello. I am using L9396 for WSS
When reviewing the WSS operation with the ST_L9369 datasheet, there is no detailed explanation regarding the Pwm Data format DATA[0...8]. Could you provide information on what each bit represents?
Perhaps you should be conversing with your local rep and FAE / Support Engineer?
Looks to be a binary count, with ~5us resolution. You could perhaps try different values and confirm what it does to the signals?
