I am facing an issue with flashing firmware to MCU SPC560P50L3 using StellarLINK probe. I have SPC5Studio 6.0.0 and UDE Starter Kit 5.2 but unable to flash.
During my investigation, I received the following information and need confirmation:
- OpenOCD does not support SPC56xx: OpenOCD only supports SPC58x family, not SPC560P. So it's not possible to use SPC5Studio + OpenOCD for flashing and debugging, is it correct?
- UDE Starter Kit 5.2 only supports SPC5-UDESTK probe: My UDE STK only works with SPC5-UDESTK probe (from PLS), and does not support StellarLINK (probe from ST). Is this correct?
- Firmware Updater Component: I found "Firmware Updater 1.5.0" in SPC5Studio but it's only a component/library, not a tool UI for direct firmware flashing, is it correct?
Main Question: Is there any tool that supports flashing SPC560P with StellarLINK probe? Or do I have to buy SPC5-UDESTK to be able to flash?
