Omission in datasheet - VNH5019
PVout.1
I am writing to report an omission in the datasheet for the VNH5019. In table 1, the list of connections for unused pins the CP pin is not mentioned.
This is fairly serious issue, as if the CP in connected to GND the controller overheats and stops working. Please add the CP pin to the table and list connection to ground as "Not allowed", as you have already done for the OUTX pins.
0 REPLIES 0
