Need help with BLDC motor driver
SS.Sagar
Posted on December 26, 2015 at 07:38
I m looking for BLDC motor driver IC which can have 15amp output current. I came across L6230 driver ic, but is giving nearly 2.5amp.
I need help to implement with l6230. I have doubt as follows.
If i use L6230 and if i connect mosfet for the three output pins, then will it work?
#l6230
0 REPLIES 0
