BNara.2
Visitor II
March 14, 2023
Need help interfacing with L9305
  • March 14, 2023
  • 0 replies
  • 1029 views
As I could not find any interface/programming guides in the software documentation section i need help interfacing the L9305 IC via SPI. Also I have a few queries.
1) In the SPI section, the MSB is R/W bit. But what does 1 mean Read or Write ?
2) What is the bare minimum configuration settings for running a solenoid valve.
Please assist and let me know if any info is required. (I've attached the SPI signal waveform i'm sending and recieving thro' a logic analyzer. Please verify and comment on the same).
