L7981 Datasheet Discrepancy
david_bleloch
Posted on March 05, 2014 at 11:26
Hi, I've started a new design using the L7981A and can't get the thing stable despite copying the reference layout.   The datasheet is not consistent with regard to the feed forward constant 1/K.  In Equation 15 it's defined as 13 yet in Equation 21 it's 9.  Which value is it please, this has a bearing on the resistor values required in the compensation loop.  Thanks
#l7981
0 REPLIES 0
