L6208 evaluation board
the_vice1304
Posted on April 03, 2003 at 08:02
the_vice1304
Posted on May 17, 2011 at 10:16
Hi folks,
where can i look for the L6208 eval kit ? (from ST ? =) )
i tried L6208 driver in dip format on a prototype board .... i burned 2 IC
so please help me to find it !
I'd like to use it for driving stepper motors in microstepping mode ....
pdelmer
The Evalboard is availble through your local Distributor (Silverstar in Italy). The Order Code should be the EVAL6208. Attached you´ll find an Application Note for implementing Microstepping with the L6208 and also the scematics.
