2013-08-26 5:52 PM
According to the datasheet, Cboost(220nF/100V) is connected between VBOOST pin and VS pin. But according to the EVKIT schematic, Cboost is connected between VBOOST pin and GND. Which connection is more recommended?
l6207-boost2013-09-04 5:43 AM
the boost capacitor can be connected both to VS or ground. Connecting the capacitor to VS is the suggested solution because it allows to use a lower voltage rating capacitor. Regards Enrico
