I want to use the STPM32, and STPM33 to measure current with Current Transformers but not measuring voltage. Have these devices some feature similar to the STPM01, which have the Single wire meter mode when there is not available voltage information?
JPedr.1
All the reference designs includes both Current and voltage measure. If I need just current, could I work with some fix voltage value ? Thanks
0 REPLIES 0
