Hi, I need recommendation for On / Off push button controller. After configurable hold time the controller will enable the system power on. After different configurable hold time the the controller will enable the system power off.
Erez.A
I need simple implementation.
Hold time for On and hold time for Off can be configured be resistors / capacitors assembly.
Could you please suggest for relevant IC?
Thanks!
Erez
Peter BENSCH
Welcome, @Erez.A​, to the community!
you can select a device from the list of Smart Reset ICs.
Hope that helps?
/Peter
Erez.A
Thank you Peter BENSCH
I will take a look...
Erez.
