Hello team, I was looking for a battery monitoring IC, I was going through STC3117, I have two questions, For what type of battery, this IC can be used? And Can we monitor the battery parameter "in live"?
CK.2
Peter BENSCH
Welcome, @CK.2​, to the community!
you put the question into the wrong category "Legace MCUs", therefore moved to "Battery Management".
The STC3117 are targeted for Li-Ion and Li-Po batteries and, as the datasheet says:
It provides accurate battery state-of-charge (SOC) monitoring, tracks battery parameter changes with operation conditions, temperature, and aging, and allows the application to get a battery state-of-health (SOH) indication.
So, yes, you can monitor the battery parameters live.
Good luck!
If the problem is resolved, please mark this topic as answered by selecting Select as best. This will help other users find that answer faster.
/Peter
Peter BENSCH
Good luck!
/Peter
