EVAL-L9963E-MCU GUI
alfonso_mauro
Hi, i made up a set up of 4 cells and I connected them to the connector of eval-l9963e-mcu. I already changed 4 cells, cause it seems like there is a dissipation for the cells. When I active the balance by GUI i don't see that the cells are balancing, oyherwise they seem like are discarge fast.
Can I know if there is someone that have used the GUI and if he as find problems like mine
Thank you so much
Max VIZZINI
Please notice that the tool you are using is out of support.
A getting started User Manual:
https://www.st.com/resource/en/user_manual/um3185-getting-started-with-autodevkit-battery-management-system-bms-evaluation-boards-stmicroelectronics.pdf
Best Regards,
AutoDevKit Team
