drive & dimm 72 leds + 72 leds all in same accurate and controlled current.
doronk
hi,
i need to drive & dimm 72 leds (vf=3.2v ;0.35A) + 72 leds (vf=2.2v; 0.3A).
i want to use low Vin such as 24-48Vmax
There are so many combinations.
What is the simplest and cost effective way, for a simple drive and dimmer (by MCU).
i want to drive the leds by current, and make sure that each string has the exact same current.
i need to control the current value by MCU
Thanks in advance
Best regards
There are lots of LED drivers out there. Perhaps look for one that suits your needs.
https://www.st.com/en/power-management/led-drivers.html
https://www.analog.com/en/product-category/led-driver-ic.html
72 LEDs at 3.2V each is way above 48V. Going to need multiple strings.
Thanks !!
i guess there is no shortcuts.. must consider the number of strings/voltage/cost/complexity...
thanks again :)
Thank you for those links, I appreciate you. Please mark it as a solution.
