Can I run 6 Step PWM generation together with ethernet?
stst9184
Posted on August 23, 2012 at 17:11
I've tried to use a tool Microxplorer (V2.1). I've played with several chips from STM32F4 and I can't activate concurrently a TIM1 6 Step PWM (field oriented controller usage) generation and some ethernet interface. Are there any (even from another families) with which I can? If yes, which one? Does exist a demo with it? If no, what MCU will you recommend me from ST?
Thank you
#stm32-ethernet-foc
stst9184
Posted on August 23, 2012 at 17:30
Problem solved. User must uncheck inn toolbar an option 'Keep User Placement'.
