BLDC CONTROL METHOD
etin_1971
Posted on October 18, 2005 at 13:43
BLDC CONTROL METHOD
2 REPLIES 2
etin_1971
Posted on May 17, 2011 at 10:19
I'm a student and i'm working on BLDC motors, could
you explain me advantage and disavantage of controlling BLDC motor
by appling PWM signal on high side of MOSFET transitsors
or by appling PWM signal on low side of MOSFET transisors
or by appling PWM signal on both side of MOSFET transistors
Thanks for your help
Best regards
Eric DUPONT
gaetano
the explanation at your question is not so straightforward!
There is a lot of concepts related to apply PWM either on high or and low side.
Fortunately for you, there is also a lot of documentation that explains everything.
So, I advice you to address the following URL:
http://mcu.st.com/mcu/modules.php?name=mcu&file=devicedocs&DEV=ST7MC2N6&FAM=15
and donwload the following ANs:
AN1946, AN2030, AN2009, AN1905.
After your reading, all should be more clear. If not, please, contact again the forum for further explanations.
Best regards,
Tanio
