Others: STM32 MCUs related
Find out more about STM32 implementations with external components, discuss use cases, and discover how to use new tools and ST components.
Resolved! RTC Problem
I use the NUCLEOH563-ZI board and I want to use RTC. I configured the RTC with the LSI clock. I loaded a default date/time. On the other hand, my time does not change...My Init code :My source code to retrieve the timeThank you for your help !Ghislai...
Option Bytes programming by Keil
I'm trying to program option bytes in STM32G4 series by Keil, I did steps below but still some problem exists:Add "STM32G4xx_SB_OPT.s" file from Keil pack directory to projectAdd "STM32G4xx dual bank Flash Options" algorithm in Flash Download tabI st...
"warning: L6314W: No section matches pattern EventRecorder.o(ZI)." -when adding event recorder to Keil project with RTX5 implemented.
Hi STcom. I have a project with the ST32L476-MCU, developed with RTX5 and the CMSIS RTOS2 on top. I want to implement the Event Recorder, and have followed this link, but as I try to build I get a warning, as stated in this question's title. I've con...
0693W000007C04PQAS.png 0693W000007C02BQAS.png 0693W000007C04yQAC.png 0693W000007C05DQAS.png
Pvon .1 by Associate II
  • 7303 Views
  • 5 replies
Resolved! Could an stm32h7 be a graphing calculator
I was wondering if an stm32h7 could run open source calculator Firmware epsilon, i would need to rewrite an interface layer, and don't want to work for days so i can find out that the stm32 is not strong enough.
Koeg by Associate II
  • 3335 Views
  • 3 replies
  • 2 kudos
