Others: STM32 MCUs related
Find out more about STM32 implementations with external components, discuss use cases, and discover how to use new tools and ST components.
Size of buffer, used by DMA
Posted on February 17, 2018 at 08:05Hello there!I want to create a library to maintain work of led-strip based on SK6812The fastest way to make it work (according to some resources: https://geektimes.ru/post/255548/ (Russian)) is to use PWM timer wi...
Atollic TrueSTUDIO feature request
Posted on February 17, 2018 at 17:43I posted about Atollic TrueSTUDIO here because it is acquired by ST. If this forum is not the right place then could you please point me to right place to ask this question.I started using Atollic TrueSTUDIO since...
STM32F3Discovery : Unknown target connected / Keil
Posted on December 11, 2012 at 20:56I just got a new STM32F3Discovery board and when I am trying to start a debug session using Keil, it is giving me an error saying ''unknown target connected'' and it fails to download code into the flash. Has anyo...
PWM input from Simulink-> PWM output TIM1
Posted on February 05, 2018 at 22:08Hi, after some problems with the interface between Simulink and CubeMX, I've managed to get the TIM1 of the STM32F767ZIT working at a desired frequency and duty cycle using the next blocks:My question is, is there...
