ADIN1110+NUCLEO-L552SE-Q communication via 10BASE-T1L
ATSUSITSUJITA
Hello.
I would like to test communication with the following configuration.
But I don't know how to achieve this purpose.
Purpose
Send and receive data between a PC and NUCLEO-L552ZE-Q via an 10BASE-T1L cable.
Devices to use
  • NUCLEO-L552ZE-Q
  • EVAL-ADIN1110EBZ
  • DEMO-ADIN1100D2Z
  • PC for monitorring
How to connect
  1. NUCLEO-L552ZE-Q ~ EVAL-ADIN1110EBZ
    The communication is conducted via SPI.
    5 connectors(GND,SCLK,MISO,MOSI,CS) are connected by jumper wires.
  2. EVAL-ADIN1110EBZ ~ DEMO-ADIN1100D2Z
    The communication is conducted via 10base-T1L.
    The 10BASE-T1L cable can be connected via pluggable screw-terminal block to connector P101.
  3. DEMO-ADIN1100D2Z ~ PC
    In DEMO-ADIN1100D2Z,Data received via 10BASE-T1L is converted to 10BASE-T and sent to the PC.
    In PC,I would like to observe the communication using WireShark.
SW setting
  • Generate source code by STM32CUBEIDE.
    <SPI parameters.>
    <Initialize SPI in source code.>
    <HAL_SPI_Transmit in while loop.>
Questions
Notes
  • I would like to use LWIP as the communication protocol.
  • This microcontroller lacks both an Ethernet connector and a PHY, making the ADIN1110 indispensable.
I would appreciate your help.
Andrew Neil
Welcome to the forum.
Please see How to write your question to maximize your chances to find a solution for best results;
in particular, How to insert source code - not as images.
@ATSUSITSUJITA wrote:
  • What kind of folder structure should be used
That's entirely up to you - choose whatever works for you.
This is what CubeIDE does by default:
https://community.st.com/t5/stm32cubeide-mcus/project-organisation-in-cubeide-how-to-go-about-libraries/m-p/734773/highlight/true#M31820
Perhaps you should try some basic projects first - to gain familiarity with the tools.
You should ask Analog Devices that - it's their product and their software:
https://ez.analog.com/search?engineerzone%5Bquery%5D=ADIN1110
https://www.analog.com/en/support.html
Consider getting their Dev Kit - or, at least, looking at the code for it.
PS:
Sparkfun have this:
https://learn.sparkfun.com/tutorials/micromod-single-pair-ethernet-function-board---adin1110-hookup-guide/software-setup
Especially as it uses an stm32!
https://www.analog.com/en/resources/evaluation-hardware-and-software/evaluation-boards-kits/eval-adin1110.html#eb-overview
via: https://www.google.com/search?q=ADIN1110+stm32
EDIT:
Oh wait - you already have this!
So you already have a working, STM32-based network setup!
So what's the point of the Nucleo?
