2024-11-11 8:43 AM
I was establishing a UART connection between X-STM32MP-GNSS2 board and PC through UART to USB converter. But, I failed to do so. Below is the error message that I could see in device manager:
THIS IS NOT PROLIFIC PL2303. PLEASE CONTACT YOUR SUPPLIER.
Request to suggest proper driver software/procedure to fix it.
2024-11-14 7:42 AM
your USB to UART converter is probably fitted with a counterfeited PL2303 IC.
Buy another USB/UART converter with a legit chip.
Personnaly using CH340 sometimes as they are very cheap.
2024-11-14 7:42 AM
