What is Instruction TCM order bit
k_arthur
Posted on April 26, 2007 at 11:35
k_arthur
Posted on May 17, 2011 at 09:42
When programming or writing to a Flash Bank, typically a ''write'' CUI command is issued and
followed by a ''read'' status register command. This ''write'' then ''read'' order must be followed to
program the flash properly. This requires bit 18 (Instruction TCM order bit) in the Configuration
Control Register of the ARM966-ES core to be set. When set, the write and read to the Flash
Bank are performed in the order generated by the ARM966-ES core. This ensures that writes
are committed to the Flash memory before any subsequent read.
Please sombody answer : What is Instruction TCM order bit.
How to find it? Is it really affects to write or erase.
k_arthur
Written in Programing manual page 14.
