what is eDesignStudio?
‎2010-02-02 5:32 AM
eDesignStudio simplifies power supply design and offers to designers the flexibility to choose the right products and topologies.
A full design is generated from the high-level requirements specified by user and provides:- all relevant parameters and results
- a full and interactive schematic
- a full and interactive bill of materials (BOM)
- a full set of analysis diagrams
- Labels:
eDesignSuite
‎2010-05-28 11:09 PM
I had to remove the tag you inserted as it was not set appropriately. Here below the text inserted in the Tags field:Hello Sir , I use ST e-Design studio for Vin 12-24Vdc to Vout 12Vdc , 1A Conversion i.e.Dc/Dc buck Application. But I didn't get any solution for any range of Dc/Dc Boost Application.Do we have any Solution for this?Best regards Peppe- Mark as New
‎2010-05-31 2:03 AM
Hello Sir,
First of all let me thank You for your interest on ST products.
If you try to select a higher value for Vin-min (Example 12.1), you will get the some solution.
So: Vin 12.1-24Vdc to 12Vdc Vout, 1A conversion could be a better specification.
The Problem is that to get 12Vin to 12Vout conversion requires a buck converter with 100% DutyCycle and at the moment this tool doesn't provide solutions like that.
Posted: Saturday, May 29, 2010 8:09 AM
Subject: what is eDesignStudio?
‎2010-06-02 1:22 AM
.ExternalClass1CBF272D79CF4908A94EDBEB44CE79C9 p.MsoNormal, .ExternalClass1CBF272D79CF4908A94EDBEB44CE79C9 li.MsoNormal, .ExternalClass1CBF272D79CF4908A94EDBEB44CE79C9 div.MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:11.0pt;font-family:'Calibri','sans-serif';} .ExternalClass1CBF272D79CF4908A94EDBEB44CE79C9 .MsoChpDefault {font-size:10.0pt;} @page Section1 {size:8.5in 11.0in;margin:1.0in 1.0in 1.0in 1.0in;} .ExternalClass1CBF272D79CF4908A94EDBEB44CE79C9 div.Section1 {page:Section1;}
While Searching on my.st.com I came across L6920 (DC/DC Step Up Converter).
(Reference : my.st.com -> ordering -> e samples ->Product class family -> Power management -> Dc/DC Conversion -> Step Up -> L6920)
But this Part number is not present on ST e-Design Studio.
Then How can we Design using this part?
Kindly Guide and Rectify if I am wrong.
‎2010-06-10 5:39 AM
‎2010-06-10 11:39 PM
Dear Kiran,
Kindly Follow following link for ST e-Design tool. with the help of this design tool you will get complete dc/dc design, BOM (in *.pdf format if you want.). http://www.st.com/stonline/domains/support/simulators_tools.htm- Mark as New
‎2015-04-30 9:37 AM
Dear friend, please tell me to whom I should contact to buy transistors STGW45HF60WD in series 10? You can give me the email address of the sales Manager?
Please write me the answer to my address: extruderplast@mail.ru
For earlier thanks a lot!
Best regards,
Dima Bond
