2019-09-09 7:47 AM
I am trying to design a power supply using eDesignSuite, having universal input from85~265VAC/50Hz and having 1 isolated output 10V@15mA and two non-isolated outputs 15V@75mA and 3.3V@50mA (flyback converter). But I am unable to design both isolated and non-isolated outputs in eDesignSuite.
Could you please help me in this regard?
Best Regards,
Anayat
2019-09-10 2:08 AM
2019-09-10 2:12 AM
could you please try to SIGN IN before starting the design? You will find the SIGN IN button in the upper right corner.
Regards,
Patrizia
2019-09-10 2:37 AM
