Use OCMPB to generate PWM Signal
Options
‎2007-02-22 4:18 AM
Posted on February 22, 2007 at 13:18
Labels:
Legacy Products
Options
‎2007-02-05 6:17 PM
Posted on February 06, 2007 at 03:17
I wanted to generate signal using PWM mode. However, the existing OCMPA pins are already occupied for other purposes. How can I use other pins like OCMPB to generate a PWM output?Options
‎2007-02-22 4:18 AM
When timer is configured in PWM mode, the PWM signal will be generated on OCMPA pins. It would be better to use the OCMPB pins for other purposes as it is already available and not used in PWM mode and use the dedicated pin the OCMPA for the PWM signal.
