USB implementation help please
michel239955_st
Posted on June 13, 2008 at 20:36
michel239955_st
Posted on May 17, 2011 at 09:53
Hi, I have a sofware running in STR9 (STR912FW44XB). I need to install a command system via usb. The mcu receive ascii command and generate action acording to them). I download the DFU_bootloader but i still don't know how to start. Can someone resume me the step to get it work. An example will be also greatly apreciate.
Thank you for your help
Michel
rgreenthal
Don't forget if you get a HW Reset that isn't from the Power on Reset you need to
// A system reset does not reset the USB registers.
_SetCNTR(0x0003);
_SetISTR(0x0000);
_SetDADDR(0x0000);
_SetBTABLE(0x0000);
