2026-01-08 6:09 PM
Hello ST
I would like to ask about is it possible to change the STUSB4500 FTP_KEY default values through SMBUS interface? If its possible, could you suggest the appropriate step to do so?
2026-01-12 5:24 AM
Dear CWei.1,
The procedure to write/read the registers is fixed, including the FTP_KEY values.
2026-01-09 2:07 AM
Dear CWei.1,
I am not sure to understand your request.
Actually, when you need to access the STUSB4500 registers, as a first step, you must write the customer access key into the FTP_KEY register using the I2C bus.
This procedure is described in the document attached. Does it answer your request ?
2026-01-09 5:19 PM
Hello
I have reviewed the document. Could you please clarify whether the default values of FTP_KEY are fixed, or if they can be modified and configured to user-defined values?
2026-01-12 5:24 AM
Dear CWei.1,
