STVD7 & Flash Memory
user
Posted on July 07, 2004 at 13:00
4 REPLIES 4
user
Posted on July 02, 2004 at 12:49
Hi to all,
could someone tell me how I can set the Flash memory every time I compile
the project ?
(e.g. I need to fill all Flash memory with $FF before start debugging)
Many Tanks
MBKS
sjo
Posted on July 02, 2004 at 13:19
STVD7 fills all memory (except peripherals) with 0xFF when entering debug mode (simulator).
It does on my version anyway - v3.00.
sjo
user
Posted on July 05, 2004 at 04:43
Hi sjo,
this is true for simulator (I tryed it end work fine) but when I use the Target ''Emu3'' on Debug Instrument Setting Form the memory doesn't
come filled up with $FF.
MKBS
alain2399
You can use the File>Save/Restore Layout from the memory window contextual menu. Beware that the PC value is reset to 0x0000 after a file restore (see release notes).
