STR9 FreeRTOS port with WEB server
‎2006-10-23 5:11 AM
- Labels:
Legacy Products
‎2011-05-17 12:30 AM
I hope it might be of interest that the latest FreeRTOS.org download includes an STR912 port with a WEB server demo. The ENET driver has been extended from that available from the ST site to make full use of the DMA on the Rx and (hopefully) auto negotiate the protocol. See for more info. Regards, Richard.- Mark as New
I can't open the link, what's wrong? Thanks.- Mark as New
I just tired clicking it an it seems fine. Try going directly to
. I know the site is not accessible from within China, so if that is where you are based there is not much I can do about it I'm afraid :(- Mark as New
I should have mentioned you can still get the source code even from within China,
but might be tricky without the documentation. The STR9 demo project for IAR is in the Demo/ARM9_STR91X_IAR directory.- Mark as New
Thanks so much. I am going to try it on the STR912 board.
I looking into porting FreeRTOS on this Micro using the Keil tool. Please help me with a good starting point Thanks- Mark as New
See the following link:
https://sourceforge.net/forum/message.php?msg_id=3835217
