2003-09-18 5:12 AM
2003-09-03 12:25 AM
Does anybody know if I need to match the PCICLKO and PCICLKI track to the PCICLKx that go to each PCI device when using a Clock buffer like the CY2305?
I´ve chosen the second implementation on the Elite datasheets (page 65) Thank you [ This message was edited by: martinwechsler on 03-09-2003 12:55 ][ This message was edited by: martinwechsler on 03-09-2003 12:56 ]2003-09-18 5:12 AM
The length of the wire between PCICLKO and PCICLKI must be identical to each other and all the other clock lines. This is a requirement of the PCI.
