STLITE29 PROGRAMMING
camagna
Posted on January 19, 2005 at 09:48
camagna
Posted on January 16, 2005 at 07:01
Hi. Is it possible to use the inDART hardware tool used for the STLITE09 on LPT with the STLITE29 device? If i use DATABLAZE version 1.17 when I select the STLITE29 I can't select the LPT port.
ldefend2
No, it is not possible.
You should use inDART-STX on USB port.
