ST7FLITEUS2M6 Register File
oc
Posted on May 28, 2009 at 19:40
oc
Posted on May 26, 2009 at 21:38
Hello all,
I am developing with the ST7FLITEUS2M6, using ST7VD and the ST7 C library.
I cannot find an appropriate register definition file (st7xxx_reg.h) for this micro, specifically one that defines both EICR1 and EICR2 registers.
I can write my own definition file based on the datasheet, but is there something I am missing?
Cheers,
James
wolfgang2399
Posted on May 27, 2009 at 08:42
Hi James,
installing the st7tools, you'll get a lot of include-files in the folder include.
The file ST7FLITEUS2.h includes definitions of EICR1 and EICR2 as well.
WoRo
oc
Ah, OK. Is there an easy way to integrate those files into the existing ST7 C library structure, i.e. device selection in ST7lib_config.h (by virtue of including the device _periph.h file)? How have other approached this?
From a brief look, I guess I should do away with ST7lib_config as supplied, and write my own based on the file in that include folder...
