ST7 Stick Programming Speed
dmayo
Posted on August 09, 2006 at 07:47
dmayo
Posted on April 27, 2006 at 13:43
To program a ST72F561 with the ST7 Stick it takes around 3 minutes. That seems rather long for programming with a parallel port (compared to other micros).
Is there anyway to speed up the programming so that it takes less time???
The computer 1.6GHz, 2GB of RAM; nothing else is running.
emmanuel23
Your chip is probably driven by a slow clock.
This clock source is configured through option bytes.
You can significantly improve your programming duration by ignoring current option bytes during the programming session: Select ICP OPT DISABLE in the configuration window.
Then, programming the whole memory will last less than 30 seconds.
Emmanuel.
