ST7 assembler code to C?
sebastian239955_stm1
Posted on February 15, 2008 at 08:17
Posted on February 15, 2008 at 07:22
Hi folks!
Since I am new here... first a friendly ''Hello!'' to everyone!
But now directly into medias res ;)
I was wondering if there is a possibility to automatically convert ST7 assembler code to a C-file??
thanks alot
Sebastian
fggnrc
Sebastian,
as you know, the C compiler translates a C source file to assembly code.
This translation is complex and is controlled by some options that change from compiler to compiler.
If were exist a tool that does what you ask, it should be able to revert its action, at least for the code that it generates.
As far as I know, such tool does not exist and I bet that it can't be made because some assembler instructions (e.g. TRAP) do not have a language C conterpart.
EtaPhi
