ST10F276 Flash
Options
‎2004-10-14 7:43 PM
Options
‎2004-10-14 8:49 AM
Posted on October 14, 2004 at 17:49Hello I want to program the flash of the ST10F276 using the flash registers, but my problem is that I read in the memory values different of the values that I had written. What could be the problem? Thanks,
Options
‎2004-10-14 7:43 PM
Posted on October 15, 2004 at 04:43
I had nearly the same problem. The data that you had read may be read from another memory and not from the flash. Check That : - ROMEN bit in SYSCON register is set . - Verify that XFLASHEN bit in XPERCON register is set in order to be able to access the Flash Control Register I hope this will help you. [ This message was edited by: Najoua on 15-10-2004 09:31 ][ This message was edited by: Najoua on 22-01-2007 11:58 ]
