Some error about DOC2000
cdvehicle
Posted on August 10, 2005 at 06:19
cdvehicle
Posted on August 08, 2005 at 08:00
I can boot diskonchip from DOS(using DOC1xx.exb.->DOC5xx.exb) successful.
I use dformat program to format doc2000-chips and doses not copy any thing to the doc2000.
when I boot from linux, the BIOS halt!,Why?(if TrueFFS working, the BIOS dead)
I can boot linux from HardDisk.
[ This message was edited by: vehicle007 on 08-08-2005 11:32 ]
kaouther
To copy files to DOC, you have to upgrade the firmware also: please use this command under DOS.
dformat /WIN:C800 /S:DOC5EXB
You can not boot because you have to configure DiskOnChip as a bootable disk for the OS used. I have attached the Installation manual for the DiskOnChip2000 with Linux OS.
________________
Attachments :
APP21.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HzBw&d=%2Fa%2F0X0000000bKX%2Fae0IhUbEEQKeETUlrpugERiICAslnNQVbsc00tSGaO0&asPdf=false
