Problem with bootloader
Options
2009-05-27 12:55 AM
Options
2011-05-17 12:58 AM
Posted on May 17, 2011 at 09:58
Hi
Does anyone here have succes with the bootloader AN 2475 IAP example, using the Hyperterminal?. I'm searching for someone who can help me with a modifyed example that works correct. If some one here have the source code for a successfully bootloader application, I'm very interested. I can see some of the others forums is about problems with this bootloader application, but did you solve your problems???. Looking forward to hear from someone. Best regards Hans
