Need info
gzerpa
Posted on March 29, 2007 at 12:51
Need info
gzerpa
Posted on March 28, 2007 at 18:43
Hi guys,
I have been programming and playing with a STR7 using the Oimex STR-P711 board, a JTAG wigler and a IAR EWARM Kickstart Version.
I have reached the 32K code limit. I would like to know if there is some IDE or a complete set of tools in order to develop a bigger program on a STR711FR2T6.
If some one could help me with the diferent tools, Pro, Cons, and even price range that are avaliable on the market... I would appreciated a lot. I have read about the Keil, IAR, Raisonance, Rowley, RealView.
I have been investigating about an open source option. Actually I am triying to use the Eclipse + CDT + Cywin + GNUARM + OCDremote that it is supposed to be an alternative for program the LPC2xxx but I dont kwon what to do with the STR711 ... may be that option is worng.
Could you help me with this???
Thank you guys
mehdi239955
Posted on March 29, 2007 at 07:56
Hi Guiy,
This is an interesting link that shows information about ST's partner and their debugger and compiler.
http://www.stmcu.com/modules.php?name=mcu&file=devtools
Find also attached, some information about ST's third parties. it should give you a clear idea. :-]
Now,if you're interested in one of this products ,ST give you the opportunity to buy on line from its web site, find bellow the link. ;)
http://www.stmcu.com/modules.php?name=mcu&file=debug_tools&fam=86
I didn't try it but normally it should work :-W .
find attached useful doc.
Best regards,
MBS
[ This message was edited by: MBS on 29-03-2007 11:40 ]
________________
Attachments :
ARM_Cross_Development_with_Eclipse.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtNp&d=%2Fa%2F0X0000000aPC%2FE97pFm2sH5f4wr.47KpUvfa.rIhX7GChceTb6WPGv9U&asPdf=false
brstrtools1006.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtNu&d=%2Fa%2F0X0000000aPE%2FHHv5nzGnWm2ifwLiaRGjhv_dvik_aq1wXmNjCACU94Y&asPdf=false
gzerpa
Thank You MBS.
