library bug
Options
‎2008-02-20 10:35 PM
2 REPLIES 2
Options
‎2011-05-17 12:49 AM
Posted on May 17, 2011 at 09:49
I think I found typo in the library
if I manualy set the SCU->PCGR0 in the code (instead of using library functions) I got error that SCU_TypeDef doesn't have member PCGR0. I think that SCU_TypeDef doesn't declare PCGR with zero but capital letter o. Same thing applies to SCU_AHBPeriphClockConfig where SCU->PCGR0 is used (and other lines of code where SCU->PCGR0 is used).Options
Hello slawcus,
You are right. Thank you for your update. Best regards, mirou. [ This message was edited by: mirou on 21-02-2008 12:09 ]
