L9678P typical circuit
wxu.15
Does anybody have this L9678P typical circuit​ and could you explain the component select method and IC pin function?
Elena BRAMBILLA
​Sorry for the late answer. Visiting the webpage of L9678P, between datasheet and application note published you should find what requested.
https://www.st.com/content/st_com/en/products/automotive-analog-and-power/chassis-and-safety-ics/airbag-ics/l9678p.html
have a look.
we have also a different version L9678P   including PSI-5 remote sensor interface
https://www.st.com/content/st_com/en/products/automotive-analog-and-power/chassis-and-safety-ics/airbag-ics/l9678p-s.html#design-scroll
Elena
