I2C S/W-implementation (AN1045)
wolfgang2399
Posted on September 11, 2006 at 08:28
3 REPLIES 3
wolfgang2399
Posted on September 11, 2006 at 05:33
is there anybody with experiences in I2C S/W-application.
I took the example of AN1045 and ported it to my Lite29-project.
In fact it works, but there are some questions which I'd like to discuss.
Thanks for reply
WoRo
laurent239955_stm1
Posted on September 11, 2006 at 06:26
Hi Woro,
The best is to ask your question(s), then may be someone can answer !
BR
Laurent
wolfgang2399
Hi Henry,
great that you replied immediately.:-D Here are my questions:
- In the ROUTINE wait_Ack there is an ambiguous sequence (twice the same code):
if(ValBit(PADR,SDA)) /* Test of SDA level, if high -> pb */
delay(2);
if(ValBit(PADR,SDA)) ....
delay(5);
1st: What's the sense?
2nd: What means ''-> pb''
3rd: Does your application work while you leave the code? I must skip it!!!
- In the ROUTINE I2C_nAck the line
ClrBit(PADR,SDA); /* The master pulls the SDA line high */
the code or the comment seem not to be correct.
Any suggestion?
- To avoid spurious changes of the output register values while using bclr or bset commands with PADR, I'd like to fix the output values before changing a port to output:
ClrBit(PADR,SCL); SetBit(PADDR,SCL);
Or better:
disableInterruptMask; ClrBit(PADR,SCL); SetBit(PADDR,SCL); enableInterruptMask;
Any experiences?
Sorry Henry, I have no idea to your problem with the odd numbers.:-[
- Did anybody else find further ambiguities or problems with the given code or has tuned it for better performance??
Thanks in advance
WoRo
