I2C on CAPS
jm
Posted on February 07, 2008 at 10:43
I2C on CAPS
jm
Posted on May 17, 2011 at 09:49
Hi all,
I start a design on STR912FAW44 and I'm using CAPS software to assign pins. But I've a problem to declare I2C0 as master. I2C0 on P2.0 and P2.1.
I check registers values generated in conf.h file :
:o
#define GPIOIN2 0x1
#define GPIOOUT2 0x8
#define GPIO_DIR2 0x0
I don't understand why P2.0 is set as I2C0_CLKIN and P2.1 as I2C0_DOUT ? And why GPIOIN register set only P2.1 as output :-[
How can I declare I2C0 master mode with the 2 pins as ouput (2C0_CLKOUT and I2C0_DOUT) in CAPS ?
Thanks in advance
[ This message was edited by: jim06 on 07-02-2008 15:16 ]
