I/O State
nambip2
Posted on April 25, 2005 at 05:03
I/O State
nambip2
Posted on April 20, 2005 at 18:12
In ST7FLITE09 , after power up how long does it take for the configuration of the I/O when i use the internal RC oscillator ? In my application i like to configure the I/O as O/P .
1. From power up until configuration of the I/O as O/P what will be the state of the I/O Pin.will this be high impedance / low / high ?
2 .From power up to valid output (I/O config.) what is the time taken ?
Prasanna
alok2
This is explained in datasheet. See Reset Sequence Manager chapter.
To answer a bit..
1. Startup time of micro : 256 cyc + PLL startup time (60 cyc) + S/w initialisation time if taken by compiler library (e.g startup.o)
2. I/o are in floating i/p = high impedance
3. once the mcu has started, you can put 1st instruction for IO initialisations.
hope it helps.
