How to determine a SMPS NTC, EMI Filter and X2 Cap values?
Thomas Ranz
Posted on March 25, 2017 at 19:28
Hi:
I have designed a smps using eDesignSuite with a VIPer38LE chip... the Power In is 11.1 watts, 96-144 Vac, 60hz and will run at 60KHZ.  Is there a method for determining the recommended filter components being X2 caps and the Common mode input choke?  Also the NTC?
Thanks, Tom
#common-mode-choke #ntc #x2 #emi-filter
Richard RENARD
Posted on May 19, 2017 at 12:10
EMI filters from ST are for datalines, not for power lines.
Best Rds
Richard
