How to add real date to compilation (Cosmic)
akel
Posted on April 03, 2006 at 20:10
akel
Posted on April 03, 2006 at 13:49
It is possible to get by compiler
real date from computer RTC
and put to defined place in Flash
memory.
I want to use it as version identifiction
Andrew
Viktor POHORELY
Posted on April 03, 2006 at 15:21
I dont think it is possible, but there is no reason to do that, isn't it better to put your own version number into FLASH and increase it in case you have made some changes into the source code?
luca239955_st
look for __DATE__ in the document clanguage.pdf that is in your compiler installation; that should allow you to somehow insert the compilation date into your executable.
Luca (Cosmic)
