How much time without power for valid RTC registers ?
tech9
Posted on October 24, 2007 at 03:55
tech9
Posted on October 12, 2007 at 15:05
Hi everyone,
We are wondering how much time can the registers for the RTC clock value (RTC->CNTL and RTC->CNTH) ''survive'' without power and still hold valid data?
We have seen that in the event of an external reset, they still contain the correct time, and even when there is a power glitch that triggers a reset.
Anyone has an idea on how much time they last with an STR710 built following the demo board configuration?
Thank you,
Tech / Jp
kleshov
My understanding of how semiconductor circuits work is that as soon as supply voltage drops below a certain level, register contents are lost.
So the question is, how long can the capacitors on your PCB hold the necessary charge?
