How many type of setting in I/O ? (by setting of PADR,PADDR,PAOR)
alanlai1
Posted on November 02, 2003 at 20:24
alanlai1
Posted on October 31, 2003 at 06:10
Thank you very much ^^
developsofter
it depends on the IO pad you are refering too, you have to check first in the datasheet.
But usually :
DDR OR meaning
0 0 floating input
0 1 pull-up input
1 0 open drain output
1 1 push pull output
But first you have to refer to the I/O ports chapter in the datasheet of the product you use.
Hope it can help
