How is the marking of M95P08-IXMCT/E?
FtF
Is this the M95P08-IXMCT/E?
Peter BENSCH
Welcome @FtF, to the community!
correct, the marking 5CXE stands for the M95P08-IXMCT/E.
Hope that helps?
/Peter
Peter BENSCH
Hope that helps?
/Peter
Dear Peter,
Thanks for your quick reply.
Your confirm helps me very much!
Am I blind? I couldn't find the Marking Information in the actual Datasheet.
Greetings
Frank
No, you are not blind. Unfortunately, markings are treated as internal information for some devices and are not always indicated in the data sheet. However, they can also be found on the label of the original packaging from STMicroelectronics - if it has not been repackaged and relabeled by catalog distributors into a smaller bag.
/Peter
